03-13-2020 12:22 AM
I have been trying to interface dsb18b20 sensor with LabVIEW using myRIO but I don't seem to get it working. It says "no channels supported" when I try to select the physical channel as voltage, any idea how to go about?
03-13-2020 01:35 AM - edited 03-13-2020 01:36 AM
Hi myron,
What have you tried so far?
How do you connect the sensor? (Any electronics schematics?)
How do you try to read its signal?
Where comes that "physical channel as voltage" into play?
Did you read the datasheet of that sensor and any information about its "unique 1-Wire®" interface?
