Driving external display using data read from digital i/o of PCI 6224
Is there any possibility to Drive external display using data read from digital i/o of PCI 6224????
(2,098 Views)
Explain what this external display is? Do you want to write from the 6224 or as you say read from something else and write to the display. Your entire post is lacking in information.
(2,093 Views)
Actually i have an idea to use the digital I/O pins of 6224. If we write on the digital lines, is it possible to get the written data on the external  LED or LCD display using DAQmx Read and Write VIs. Or can you suggest me any applications for using those digital I/O's.
(2,085 Views)
