Drivers for PCI-DIO-96
Can someone in NI tell me how to download NI DAQ software for the PCI-DIO-96 that will work with windows vista
(4,221 Views)
Hi
That depends on what LabVIEW version you are using and if you are after DAQmx or Tradition DAQ. The device is still supported in DAQmx 9.1.1 (as per the readme). That version is avaliable for Vista, but you'll have to check if it's compatible with your LabVIEW version. If you want Traditional DAQ the latest version is 7.4.4, but is only officially avaliable for XP/2000. That said I currently have it installed on Windows 7. I've nver actually used them since I reinstalled but they did insall and I have seen them installed on Vista machines as well. Give it a try and see.
Best Regads
David
NISW
(4,215 Views)
