03-11-2021 05:42 AM
So sorry for wasting all of your time. It was completely my mistake and I found out what my mistake was. There were two slots of NI 2352 switch matrix in the PXI chassis. So when I was copying from the original program I was using the right slow. But when I was programming on my own I was using the wrong slot. That is why it was not working. Sorry guys and thank you.
03-11-2021 06:29 AM
All the wisdom learned here regarding where the drivers should go and why still apply here, though. If it's possible to do - and I understand it may not be your choice - try to follow it.
03-11-2021 07:17 AM
Yes thank you, I will do that.
03-11-2021 09:31 AM
Could be worse!
<Sea Story time>😷
Back in my Navy days I was an Electronics Technician. You wouldn't believe how often we got awakened at O-Dark:30 to "Repair" something that was "Broken" only to find that the "On Normal / On Full Force" switch was engaged in the OFF position. And yes, that's how we wrote up the repair report, "XYZ Unit found on full force *** Switched to on normal."
