05-03-2008 03:31 PM
05-08-2008 03:10 AM
Hi Lee
Its cool to install things into different places on your drive - sometimes its essential. there is also an easy solution to your problem. What you have at the moment is different drivers and programs spread around your computer with no links to each other so they are unable to reference each other. To create these links yopu will need to mass compile.
Within LabVIEW go to the tools menu and then select Advanced>>Mass compile. This will bring up a window that will allow you to select a directory. Select the directory that you have saved all your DAQmx drivers and then select mass compile.
This should allow you to see all the VIs in the correct menus within labVIEW.
I hope this is of some help to you
best regards
05-19-2008 02:43 PM
05-20-2008 03:41 AM
