05-19-2021 08:16 AM
What driver is used for the PCI 6259 card? I was not sure where to find the download for this driver or figure out what driver it needs. Thanks!
05-19-2021 08:24 AM
Unless anything is listedc in the readme file, the DAQmx driver should work:
https://www.ni.com/da-dk/support/downloads/drivers/download.ni-daqmx.html#348669
05-19-2021 08:49 AM
I thought there was a nice chart somewhere stating the starting and ending versions of DAQmx support for instruments, but I could not find it.
But a warning: The PCI-6259 is listed as being in the "Mature" life cycle. This means it is one its way out of production. Not surprising since I have noticed NI is trying to get away from PCI, instead upgrading things to PCIe or USB. It is getting difficult to find PCs with PCI as well. But I just noticed the USB-6259 is also in the Mature status as well. So this is likely due to parts obsolescence. M-Series boards, in general, have been slowly going obsolete. So I would recommend doing some research and look into using a newer board and possibly upgrading your computer as well.
But as already stated, you just need DAQmx. Be sure to find a version that is compatible with whatever version of LabVIEW you are using (NI-DAQmx and LabVIEW Compatibility).
05-19-2021 08:55 AM
For the DAQmx driver you have to read the readme file/page.
https://www.ni.com/pdf/manuals/374768ah.html#MSeries
It seems that version 20.7 is compatible with your card.
But if you need a version for Win7 32bit, then you need to select another version, maybe version 19 or so.
05-19-2021 09:08 AM
@dkfire wrote:It seems that version 20.7 is compatible with your card.
DAQmx 20.7 is the first version to drop Windows 7 support (not just 32-bit, but all Windows 7). So if you are using LabVIEW 2020, I would recommend using DAQmx 20.1. Otherwise, you just need a DAQmx version that is compatible with the version of LabVIEW being used.
