‎05-01-2010 07:11 AM
altenbach wrote:This is one of my standard templates. You can find many instances here in the forum. 😄
Searching for those standard templates. Does anybody (everybody) actually use these methods? Are there replacement subVIs?
‎05-01-2010 12:55 PM
I always thought that the inner workings of LV already implement the algorithm of ManagedAddItems.vi (doubling the allocated memory each time we run out of it).
That 'knownledge' is based on my early beginnings using LV 5.
Felix
‎05-01-2010 05:11 PM
They don't and it's the delete elements which is more time consuming.
Are there some standard VIs ppl use to implement the techniques discussed?
‎10-09-2012 03:48 PM
The "Filter 1D Array" function in the OpenG library does not use this technique either... it is comparable in performance to the 'SimpleRemoveItems.vi'
‎10-09-2012 04:32 PM - edited ‎10-09-2012 04:34 PM
It was pointed out in 2007 that the openG version of "delete elements from array" is slow and inefficient. I wonder if it ever got improved... See here for details (read the entire thread for my even better code!)
‎10-10-2012 07:17 AM
Here's an even more up-to-date thread about the OpenG Array functions. There were a bunch of updates proposed to make them faster. I'm not sure what the status is on getting the library released though.
http://lavag.org/topic/15980-openg-filter-array-revised/
‎10-10-2012 07:56 AM
As you upped this thread I tried the same benchmark with the conditional tunnel.
Here are my results.
Bucket: 11 ms
LV2012 conditional tunnel : 87 ms
Managed: 107 ms
SimpleAdd: 179 ms
SimpleRemove: 8330 ms
