Downconvert VI Requests
@Sonjce wrote:
Can someone please convert the attached project from 9 to 6?
Here they are in LV8.0.  Someone else can take them to 6.0.
I do not have LV8.0 which is needed to transition across 7.x.
Message 931 of 1,444
(2,121 Views)
@Sonjce wrote:
Can someone please convert the attached project from 9 to 6? 🙂
Thanks in advance,
Sonja
Attached as 6.0. Not really much there.
Message 932 of 1,444
(2,117 Views)
Could you please convert this vi from labview 8.6  to labview 6.1.
Thanks Jeff
Message 933 of 1,444
(2,107 Views)
could you please convert this library from labview 9 to labview 6.1?
Thanks Jeff
Message 934 of 1,444
(2,101 Views)
Thanks Jeff
Can't. That VI simply calls the SMTP Email Send Message VI (there are no other VIs used), and LabVIEW will not allow you to downconvert VIs from vi.lib.
Message 935 of 1,444
(2,098 Views)
I'm trying to run a labview 2009 vi on Vision 2009. But I keep getting an error message saying that Vision can only run Labview versions 8.5 or older.
Could you please help me convert the attached file into 8.5 or older?
The program opens and closes a pressure valve, and produces a waveform and live pressure readings from an air tank.
thank you,
B.J.
Message 936 of 1,444
(2,086 Views)
Here is it in version 8.20
Message 937 of 1,444
(2,074 Views)
Hi
Would somebody be able to downconvert these VI's
Written in LabView 6 to Labview 5.1
Thanks in advance
Barry
Message 938 of 1,444
(2,065 Views)
@barrys wrote:
Hi
Thanks in advance
Barry
You're missing a couple of subVIs. I was unable to downconvert the main VI as LabVIEW 6i kept crashing (most likely due to the CLFN). I've attached a picture of the main VI so you can recreate it.
Message 939 of 1,444
(2,056 Views)
This vi was written in v8.6, but I need it downconverted to v8.0. Could someone do this for me? Thank you!
Message 940 of 1,444
(2,054 Views)
