Downconvert VI Requests
Please use the Version Conversion board to post any requests to upconvert or downconvert your VIs.
Message 1431 of 1,444
(1,888 Views)
Ok, will do.
Message 1432 of 1,444
(1,852 Views)
Hello I have problem whit my labviev 2010.I can not open vi form labview 2011 in my 2010,so I need help whit conversion a vi from 2011 to 2010
Message 1433 of 1,444
(1,830 Views)
See the new board for these requests and start a new thread there. http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Edit: Make sure you mark the reply as solved and give kudos to the person that helps you.
LabVIEW 2012
Message 1434 of 1,444
(1,825 Views)
I need to downconvert from 2010 to Labview 7.1
KB29
Message 1435 of 1,444
(1,804 Views)
Read the previous post!
Message 1436 of 1,444
(1,799 Views)
COME ON PEOPLE.  PLEASE READ THE POSTS BEFORE YOURS BEFORE POSTING INTO A THREAD.
THIS THREAD IS DONE.  DON'T POST ANY MORE REQUESTS HERE. THERE IS A NEW CONVERSION BOARD.
Version Conversion
Message 1437 of 1,444
(1,795 Views)
To be fair (generous, perhaps) I am guessing that people are not replying at the end of the thread, but rather at the beginning.  This is why I requested here to have these threads moved to the Version Conversion thread so searches at least land them in the right board.
http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/New-Board-For-Upconvert-Downconvert/m-p/184...
If they have to stick here, could they at least be locked?
In addition, perhaps the moderator could edit the original post (most likely one to be read, if any) to indicate that these threads are deprecated.
Message 1438 of 1,444
(1,776 Views)
Could smoebody help me to convert this VI code (11.0) down to (9.0)? Thanks a lot.
Message 1439 of 1,444
(1,770 Views)
holo1, are you joking or is this a weird coincidence? Go to the Version Conversion board and click the big blue button that says New Message. Make sure you mark the solution as Accepted Solution after someone helps you. But LabVIEW 2011 is capable of saving for version 9.0. Click File/Save For Previous Version and select version 9.
LabVIEW 2012
Message 1440 of 1,444
(1,768 Views)
