Downconvert VI Requests
Minx wrote:
May somebody can downgrade this vi (labview 2009) to labview 8.5 version?
source LabVIEW version: Labview 2009
target LabVIEW version :Labview 8.5
Thanks in advanced
Here it is, in its very badly written form.  Clearly written by a text-based programmer. If I were you I'd rewrite it.
Message 181 of 1,444
(3,058 Views)
wd8ivl wrote:
Could someone please convert the attached VI to LV 7.0?
Thanks in advance,
Mike
It's attached, but I doubt it will work, since it uses the System.Net.Mail, and that was introduced in .NET 2.0, which is not supported in LabVIEW 7.0.
Message 182 of 1,444
(3,046 Views)
Can you convert this from LabVIEW 2009 to 8.5.1?
Thanks for the help,
Rob
Message 183 of 1,444
(3,006 Views)
Rob
Try the attached.
Message 184 of 1,444
(2,987 Views)
  Can anyone please downconvert the attached VI to 8.5? I need it kinda urgently. Thanks in advance.
Message 185 of 1,444
(2,967 Views)
Message 186 of 1,444
(2,961 Views)
Can someone please downconvert the following vi from 2009 to 6.1. Much appreciated!
Message 187 of 1,444
(2,952 Views)
I mistakenly overwrote this LV7 file into LV9 format. Would anyone be kind enough to convert it back to LV7 format?
I attached the file in version 9 format, then in version 8 format if needed, but I'm not sure I converted it properly.
Thank you,
Message 188 of 1,444
(2,896 Views)
Message 189 of 1,444
(2,881 Views)
Thank you very much. But I cannot open this file yet; I still need it converted to version 7.0...
Thank you for your help,
Message 190 of 1,444
(2,846 Views)
