01-13-2014 02:09 AM
I need help with coming out with a design where the font is in dot matrix and the text comes out as such
A B C D E F G H ( first 8 letter)
B C D E F G H I ( A is removed and i is added)
C D E G G H I J ( B is removed and J is added)
it works like a scrolling text but is letter by letter and has spacing.
Thanks for any help 🙂
01-13-2014 02:14 AM - edited 01-13-2014 02:15 AM
Hi ZX,
to make it the easy way:
- Search for a font that fits your needs. There are free font sources in the internet.
- Then setup a string indicator to use that font.
- Then program a loop that puts a single char followed by a space in the indicator.
- When the string in the indicator holds more than 16 chars you just delete the first two chars (letter and space)...
This is a forum of volunteers, and no programming service! Attach what you have programmed so far and we will give suggestions on how to improve…
Asking for a solution (by writing long text) will most often only yield in an answer with long text. 😄
