Does the Modulation Toolkit support digitizers NI-PXI-5124 and NI-PCMCIA-5102?
I am using a demonstration NI-PXI unit to determine if it will support the application I am trying to develop. I need to demodulate a signal and determine the Quasi-peak value of the demodulated signal. The Modulation Toolkit states that it works with the 100MHz class of digitizers. Does it also support the 20 MHz and the 200 Mhz class of digitizers (NI-PXI-5124 and NI-PCMCIA-5102)?
(2,151 Views)
Kent,
The Modulation Toolkit is fairly robust. I believe that it will work fine with the 20 and 200 MS/s boards. However, these obviously have to stay towards the lower frequency end of the spectrum. The Modulation Toolkit is most powerful with NI's RF products and is designed to do so. However, as I said, I believe that since the MT stays mostly on the software side and does not care too much about hardware it will not care about where the signals are coming from and will work for you.
(2,137 Views)
