Does someone know the best way of doing what I am doing here?
My code is working as it should. I'm just trying to find a way of not using the elapsed time. Can someone please help?
Goal:
I will be turning the button ON and OFF repeatedly.
If I keep button false for more than 15 second, signal light will be ON.
If I keep button true for more than 10 seconds, signal light will be ON
Otherwise, keep signal light  OFF.
(979 Views)
Have you ever wondered what would change if you just remove the select function?????
(973 Views)
Accepted by GRCK5000
Maybe something like this?
(963 Views)
Yes, that select was definitely unnecessary. I didn't think. lol  smh
Thanks Mr. Altenbach! Your code works great!
(929 Views)
Here's how I would do it.
(890 Views)
Goal:
The Elapsed Time express VI is probably one of the few express VIs you can use without getting your head chewed off.
Bill
CLD
(Mid-Level minion.)
(878 Views)
Behavior is incorrect. LED should go ON a certain time after change.
Your inherits from the control value, e.g. it stays ON for a while if the button is turned off while the LED is ON.
(IMHO, My flat code is simpler than three event cases and terminals hidden in an innermost case structure 🙂 )
(876 Views)
