Does someone have a VI for Steam Tables?
I'm looking to graph the saturation temperature for a given Pressure and Temperature input. Does someone have the Steam Tables in a VI?
Message 1 of 10
(4,432 Views)
Steve,
There seems to be trial downloads in excel formats.  you could then read from them and re-write them to a text file to be used later.  However, reading the download page policy should be done to see if that would be illegal.
http://www.chemicalogic.com/steamtab/downloads.htm
Chris
Message 2 of 10
(4,405 Views)
Don't know if this will help, but you can find an open-source implementation of steam tables at http://pye.dyndns.org/freesteam/
It's a C library that you might be able to compile into a DLL for use in LabVIEW.
Message 3 of 10
(4,371 Views)
Some work has been done in freesteam (http://freesteam.sourceforge.net) to link it to LabVIEW. I haven't tested it; it was a user contribution.
You can see the code here:
http://sourceforge.net/p/freesteam/code/682/tree/trunk/labview/
Message 4 of 10
(3,861 Views)
Does Library file has something to do with 32bit and 64bit Labview?
Message 5 of 10
(3,611 Views)
freesteam being C code that gets compiled into a DLL, you bet that it is important to use a DLL compiled for the same bitness as what your LabVIEW environment is.
Rolf Kalbermatter
My Blog
Message 6 of 10
(3,594 Views)
I have written a LabVIEW VI for the ASME Steam Tables.  It is currently in beta testing and if all checks out, we will start using it for designing/analyzing the steam plant for the Empire State VI (https://en.wikipedia.org/wiki/TS_Empire_State_VI)  at SUNY Maritime College.  The current version assumes pressure is known.  This LabVIEW VI is planned to be expanded later.  No name has been assigned yet.
Message 8 of 10
(2,879 Views)
Yes, I wrote one.  I am at SUNY Maritime and my students use it for Marine Engineering Design 1.
Message 9 of 10
(1,910 Views)
Hi maddog,
mind to share this VI, when you advertize it again after to more years?
Message 10 of 10
(1,892 Views)
