04-11-2001 06:31 AM
04-12-2001 04:30 PM
04-12-2001 05:23 PM
01-15-2007 01:32 PM
01-15-2007 01:33 PM
10-29-2007 04:24 AM
Hi Lukasz!
In 2007, I have the same problem as Albert did in 2001 but with a RTC3 board. I even failed at the first Ctrl command "load_correction_file". Although I' m (almost) sure, that I have configured the CallLibraryFunction-node correctly, it produces the error message "An exception occured within the external code called by a Call Library Node. This may have corrupted LabVIEW's memory. You should save any works to a new location and restart LabVIEW. VI was stopped at Call Library Function Node 0x1D4 of subVI".
I have to confess that I am a physician. A reply for dummies would be very helpful as it is urgent for our project to control the laser scanner.
Many thanks in advance!
Best regards
Martin
10-29-2007 12:19 PM
11-01-2007 05:21 AM
Hello Lukasz,
many thanks for your immediate reply. Your and my VIs were completely identical, but after some time a found my stupid mistake: the filename had a little typing error (a physician's mistake...). May I disturb you again In case of being confronted with other problems?
By the way: We work on soft tissue structures of the neck... It was a pleasure, thank you very much for your help!
Best regards, Martin
11-01-2007 05:47 AM
11-01-2007 10:14 AM
