Does cRIO-9022 controller support LV RT 8.5.1?
Hi, everyone.
Thanks.
Daniel R.
CLD
Message 1 of 10
(3,798 Views)
Yes I believe cRIO-9022 does support Real Time 8.5.1.
Bruno Noronha
Certified LabVIEW Associate Developer
Using LabVIEW 8.6
Message 2 of 10
(3,785 Views)
Thanks for your answer, Bruno.
Why do you "believe" that?
Cheers,
Daniel R.
CLD
Message 3 of 10
(3,772 Views)
I "believe" because I searched ni.com and couldn't find anything about software limitations with cRIO. I talked to a couple people I know that work with cRIO and they said that software version isn't a limitation. Basically you could run cRio with LV RT 7 without a problem.
However I'm not 100% sure about this.
My advice is:
Try it and see.
Good Luck!
Bruno Noronha
Using LabVIEW 8.6
Message 4 of 10
(3,770 Views)
Thanks for your advice.
I searched also and found no explicit restriction. However if I had the controller here I would not be asking.
Cheers,
Daniel R.
CLD
Message 5 of 10
(3,766 Views)
Well I searched a little harder and found a sollution.
cRIO 9022 uses  NI RIO 3.0 .1 which is only supported by LabVIEW Real Time 8.6
In other words if you want to use the 9022 you're going to have to update to 8.6.
Best Regards
Bruno Noronha
Using LabVIEW 8.6
Message 6 of 10
(3,763 Views)
Best Regards
Well, not really.
We have a cRIO-9014 running with NI-RIO 3.0.1 and LV RT 8.5.1.
"Maybe" that implies that cRIO-9022 will run with 8.5.1, but I would like someone to confirm if there is no limitation to use 9022 and 8.5.1.
Daniel R.
CLD
Message 7 of 10
(3,754 Views)
I would really appreciate someone from NI to answer this question, since we will make some buying decisions based on this.
Thank you,
Daniel R.
CLD
Message 8 of 10
(3,727 Views)
Accepted by topic author Daniel_Chile
Hello Daniel,
This document indicates that you will need LabVIEW 8.6 and NI-RIO 3.1.0 to use the 9022 controller.
Message 9 of 10
(3,719 Views)
Thank you, so much. Very clear.
Kind regards,
Daniel R.
CLD
Message 10 of 10
(3,706 Views)
