02-05-2007 02:57 PM
@mattypiper wrote:
rolfk,
Can you post an image or VI of an example of this robust TCP/IP communication you are describing? You have a very good understanding of the nature of TCP/IP comm and I'm sure this lesson learned could be used in other comm protocols as well. \
I am interested to see an example of the error-handling architecture you have implemented. The scenario "Timeout, Retry, Timeout again, Close connection, Open connection, Retry, Success" is probably very common and a great way of dealing with undetermined network latency.
Cheers,
--Matt
That are typically libraries contained in rather huge applications (usually some 600 to 800 Vis). Stripping out the relevant part is not something to do in a matter of a few minutes and I would want to do some other stuff at the moment.
However a very good starting point "robust TCP/IP" on www.labuseful.com. This is already a very reliable 24/7 TCP/IP connect, disconnect, reconnect VI set using some if not all of above recommendations somehow. Jack Hamilton is an old time LabVIEWer and has created great software.
Rolf Kalbermatter
02-05-2007 07:54 PM
02-06-2007 02:48 AM - edited 02-06-2007 02:48 AM
Message Edited by rolfk on 02-06-2007 09:49 AM
