Does anyone know how to the invoke node "Reinit to Default"? (see attached VI)
@GRCK5000 wrote:
Thank you very much Mr. Altenbach. This is great! I learned to stay away from feedback node. I'll stick with shift registers from now on thanks to you.
The feedback node and the shift register can do exactly the same and one is not "better" than the other. In 55% of the cases, a feedback node is better, so learn how to properly use both. (For example, duplicating the global initialization option of a feedback node would require significantly more code using a shift register because they don't have it. There are other important differences so the decision needs to be done case-by-case!)
(There is never just one absolute truth as some politicians and religious leaders want you to believe)
Message 21 of 23
(611 Views)
Thanks Kevin P. Good to know!!!!
Message 22 of 23
(600 Views)
Thank you Mr. Altenbach! Definitely good to know.
Message 23 of 23
(599 Views)
