Does anyone know how to save real time data from KEithley 6485 driver in a array/waveform?
I want to use Keithley 6485 Picoammeter for real time data acquisition. I am using the driver provided by Keithley without a manual.
I am new to both Labview and Keithley. I am using a Read command in For loop for multiple readings. But I do not know how to save or plot data from each loop in real time.
(3,503 Views)
If the for loop is returning a single value, you should just write to a chart inside the loop. When the wire exits a for loop, by default it is an array. You can write this to a graph.
(3,464 Views)
you can see at the atteched file
(2,801 Views)
