Hi JSI,
The PXI-6123 does not have the programmable input filters like the
M-series boards do. What you can do is implement the same thing using
the counters as a debounce circuit.
Here is a knowledgebase article that gives more details on how to do this.
What will happen is the counter will be configured to output a single pulse when a rising (or falling) edge is detected on the gate. This single pulse will be configured to have a width such that a subsequent rising (or falling) edge on the gate will be ignored. The counter will re-arm when the single pulse is completed. The pulse width should be chosen to be short enough that the counter will re-arm in time for the next input to the counter, but long enough to ignore switch bouncing or other accidental duplicate inputs.
Look at the shipping example for LabVIEW: Gen Dig Pulse - Retriggerable. Search for Pulse in the Example Finder or browse to the Counter Generation examples.
Your digital input will then be configured to read from the PFI line that represents the Counter output.
Have a great afternoon!
MatthewW
