10-15-2006 02:42 PM
10-15-2006 06:53 PM
10-15-2006 07:02 PM
10-15-2006 07:17 PM
10-15-2006 07:21 PM
10-15-2006 07:30 PM
10-16-2006 09:52 AM
I had some time this morning and I wrote a small routine that pads dimensions with the PSF minimum value (rather than zero) thinking that that allows us to potentially skip the Weiner formulation if not needed. I padded only to the minimum number needed, and in fact the routine can have dimensions off by 1 (indeed that is the case in this example) but the result seems to be valid. This can likely be tweaked and optimized but it was a simple solution for now. So yes, it does appear that the dimensions are required to be (about) equal to allow us to carry out the deconvolution. Thanks again for taking the time to look at all of this and making great suggestions.
Sincerely,
Don
11-14-2007 10:06 PM
11-15-2007 09:40 AM
11-15-2007 09:53 AM
You CAN use both versions of LabVIEW on your machine at the same time.
The 'swap quadrants.vi' is needed to reposition the results so that the deconvolution results display properly.
Sincerely,
Don
