01-19-2010 05:29 AM
Most of the train systems today use MVB (Multifunction Vechicle Bus) communication. Does labview support it and are there NI hardware compaitable with it. Any information on this matter will be very helpful.
Thanks in advance.
Prav
01-19-2010 07:24 AM
06-19-2010 12:37 PM
have you found a solution yet? Otherwise talk to the company that offers many MVB products, they have done some LabVIEW drivers for some of their products. www.duagon.ch
07-04-2011 07:25 AM
I am in the same condition. Haven't you found a solution yet? Did you evaluate the Duagon boards?
Thanks a lot.
07-11-2011 10:00 AM - last edited on 07-11-2011 10:34 AM by Laura F.
Duagon (www.duagon.ch) is offering a cPCI board that works in PXI systems. The also have LabVIEW drivers for Windows and LabVIEW Realtime. We have tested them both this spring and they just worked fine. In case of any unforseen issues there is also a very helpful engineering contact @ Duagon. His name is Joerg Rapka.
07-11-2011 10:07 AM
Good news, thanks. I will try it.
Let me to take advantage of yuor expertise, do you know some similar board for WTB (Wired Train Bus) ?
Thanks.
02-15-2012 09:04 AM
Dear Christian,
we requested technical and commercial information from duagon regarding the MVB cPCI D215 board and they told (and write into the offer) that no LV driver are available for that board.
We can use only the API doing at least a wrapper in LV.
Do you have different information about that?
Where we can find the driver you mention?
01-10-2014 12:32 AM
hi,do you solve the program the D215 card wors in PXI system with LabVIEW RT?
I have been puzzled for one Month. Can you tell me the solution?
Thanks a lot!
09-04-2019 07:39 AM
My company (Tritem) prepared the MVB drivers for duagon boards both for Windows and LabVIEW RT (Pharlap).
The driver can be used in a regular LabVIEW code, but we've implemented also a VeriStand Custom Device for it.
If you are interested do not hesitate to contact me.
