Documentation for "Eval Formula"
Dear all!
I am reading through the documentation surrounding the mathematics library for parsing and evaluating text formulas. In particular I am looking for a grammar and list of avaiable symbols and functions. However, I am unable to find them. Is there a more detailed documentation available somewhere I have not looked? Obviously, the parsers are similar to other formula nodes (https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/gmath/differences-between-the-parse...)
I also do not understand the remark in https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/gmath/parser-llb/parse-formula-stri...
- What should I "Keep [...] in mind for [my] own programming"?
(1,917 Views)
Accepted by topic author LLindenbauer
Hi LLindenbauer,
The formula parser differs to the formula node as is written in the help:
The parser in the Mathematics VIs supports all elements that Formula Nodes support with the following exceptions: …
The following table lists functions that the parser in the Mathematics VIs supports but Formula Nodes do not. …
So you can read the help for the formula node, but need to keep in mind the differences as listed!
(1,913 Views)
I see. I was confused since formulas such as
float32 a = 1;
b = a+a;
fail not evaluate, but are valid in Formula Nodes. As I understand it now, the parser is somewhat simpler and accepts what is essentially a single right-hand-side expression.
Thanks for the reassurance.
Best Regards, L.
(1,891 Views)
