Divide the 10MHz Bandwidth signal into two 5 MHz signal.
I hope everyone is haveing a productive day.
I am receiving a signal of Bandwidth 10MHz with Labview using X-310 receiver.
Now i want to know about a filter to divide the signal into two 5 MHz signals for further processing
E.g.88-98MHz signal to 88-93MHz amd 93-98MHz signal.
(1,173 Views)
Hello.
You can pass the receiving signal into two filters in which you can mention the cutting frequencies in order to get your desired frequencies.
From (Waveform Conditioning) choose the Filter and modify it to be (Low pass, High pass, or Bandpass) to get the bandwidth you need to pass for further process.
Find in the below:
Regards.
(946 Views)
