Reply
Displaying the Temp. at different location by selecting in front window tab
hi,
i am trying to develop a system to displaying the tempurature as well as control. please find the attached picture file to give a better view regarding my quastion.
this program contain few tabs.
page 1- page which is the user will select the location of thermocouples. once the thermocouple location selected, the selected name will be used as a reference in logging TXT file as a header of the coloum.
page 2,3,4,5 and 6 - page which will display the selected tempurature
problem:
the agilent data logger has only 40 thermocouple logging capability. the system will have about 80 to 90 thermocouple locations. so the user will select different thermocouple location at beginning of the testing for given thermocouple.
for example:
if the user select the thermocouple 1 is assign to location T1 - 3 then the reading of thermocouple 1 should display on the page 3 at correct location. on the next test the thermocouple1 could change to T1 - 8.
this few days i spend good couple of hours on this problem and the solution still some where in the sky!!!! or no solution for this problem.
(674 Views)
Hello siva,
from page 1 you got 2 numbers: which thermocouple to read and where to display.
You wire the number of "where to display" to the selector of a case structure. Each number is a case, in this case you have the terminal of the correct indicator. (So for instance in case 0 you have indicator 1 on page 2, in case 10 it's maybe indicator 3 of page 4 and so on.) The value of the thermocouple is written to the selected terminal.
Simple straight solution :-)
CLAD expired, using 2009SP1 + LV2011SP1 + LV2017 (+LV2018 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
(669 Views)
could you show an simple example please,
siva
(666 Views)
Hello siva,
here comes an example... (LV7.0)
(663 Views)
the solution which you posted helped me indirectly!
please find the attached file
siva
(651 Views)
