12-08-2017 11:39 AM
What is the best way to display (for lack of a better term) "pretty looking" equations on the front panel? I want to display equations that look like they would in LaTeX or Microsoft equation editor. Thanks.
Solved! Go to Solution.
12-08-2017 12:04 PM
Are the equations set or can the user edit them? I would generate the pictures beforehand and display them in a picture control.
12-08-2017 01:17 PM
The equations will be set. This seems like a good idea, but I have never used a picture control before. Could you provide an example?
12-08-2017 02:10 PM
12-08-2017 02:39 PM
This link may guide you in a possible direction. You can use it to create a gif of the equation and then display it in a picture control.
Ben64
12-08-2017 03:30 PM
Also have a look at Darin's Math Node for some possible ideas. (not quite the same, but still....)
12-08-2017 03:38 PM
You mean something like this?
Like everyone else said make it a picture and just place it on your panel.
I think I made the formula using the Equation Editor that was part of MS Office.
12-08-2017 03:58 PM
12-08-2017 04:22 PM
@ben64 wrote:
Unfortunatly there is no way to export the result of the Ms Equation Editor to another application.
Ben64
Also: altenbach thanks for posting that link. I hadn't run into it before and that is fantastic code.
12-08-2017 07:29 PM
