Displaying File contents to a Graph
Hello
I am currently saving data from a labview application into a text file. It contains multiple columns and rows. the 1st column is time and date data in the format the client prefers, subsequent columns displays temperature data. I would like to be able to display this data on a graph with the 1st column(time and date) being on the x Axis and then subsequent columns showing the temperature data.
The temperature data is straight forward to handle but I am struggling to get the correct format on the time date column for the X axis.
I understand maybe a solution is to initially save the date.time in different format, but i would prefer to work with the file contents as it is now.
Many thanks in advance.
I have attached a sample file
(1,839 Views)
Accepted by topic author LeeBowers1
Hi Lee,
Try ScanFromString with %<%d/%m/%Y %H:%M>T to scan the timestamp...
(I guess it is day first, month 2nd because of the "Winter" mode - and the 24h mode. 🙂)
(1,834 Views)
Hello
Yes, scan from string - works a treat 🙂 Once I worked out format for input, in my case ending up being %<%d/%m/%Y %H:%M>T
I have attached my interim solution, ready to build into my applicaiton
Thank you
(1,799 Views)
@GerdW wrote:
Hi Lee,
Thusly
The display is m/d/Y but that does not change the DATA of output 1 (Timestamps are stored internally as UTC)  Its that "%<>T" that clues LabVIEW to use an Absolute Time container
"Should be" isn't "Is" -Jay
(1,789 Views)
