From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Displaying 2 XY Graphs in the Front panel make the graphs start lagging
Hi everyone,
I am using a controller that sends data to LabView in the form of strings of data. These strings of data contain various parameters at different timepoints, which I can separate by the commas.
After that, I put this data in a sliding buffer that feed the array to two different graphs.
The array is then feeded back to the sliding buffer by a shift register and new data keeps being added.
I adjust the X axis using property nodes to define the minimum and maximum range.
While troubleshooting, I deleted one of the graphs, and the lagging of the data disappears completely.
The array in the sliding buffer can have 5000 points. I tried decreasing this and it did not help.
Message 1 of 8
(577 Views)
Hi Icy,
Did you also delete the ExpressVIs before that graph?
Plotting 5000 points in a XYgraph might need some processing time…
  • Do you need to update the graphs in each iteration?
  • Do you really need to use ExpressVIs for this task?
  • Why don't you create those plots inside your "Sliding buffer" subVI? (Using NO ExpressVIs…)
  • Do you need to fiddle with graph properties in each iteration?
  • Why don't you use autoscaling?
  • How fast does your loop iterate?
  • Why don't you attach code, but just an image of code?
  • Why don't you separate DAQ (aka VISARead) from UI handling (aka graph updates), using a producer-consumer scheme?
So many questions…
Message 2 of 8
(564 Views)
I've been told writing to property nodes is a slow operation. See if you get back some performance by only writing to them when "Human gait cycle control" or "Graph Width" are changed.
Are you limiting loop speed by using the 'Wait (ms)' or similar VI? That might be helpful to add if you're not currently doing this.
"Computer Emergency"
Message 3 of 8
(558 Views)
  • Do you need to update the graphs in each iteration? No
  • Do you really need to use ExpressVIs for this task? Also no.
  • Why don't you create those plots inside your "Sliding buffer" subVI? (Using NO ExpressVIs…) I will try that.
  • Do you need to fiddle with graph properties in each iteration? No, I only need to make sure that the X and Y axis accompany 5 seconds at each time.
  • Why don't you use autoscaling? I tried that but the data was not getting displayed for some reason.
  • How fast does your loop iterate? I do not know.
  • Why don't you attach code, but just an image of code? I work in a company and I am afraid to breach confidenciality.
  • Why don't you separate DAQ (aka VISARead) from UI handling (aka graph updates), using a producer-consumer scheme? Will look into that.
Message 4 of 8
(519 Views)
How can I make it so that it only writes to the property nodes if some value is change?
And about the wait, I added a basic wait time for the whole loop and it helped a bit but it did not fix it completely.
Message 5 of 8
(516 Views)
Hi Icy,
Use a case structure to execute code based on a condition…
Message 6 of 8
(510 Views)
You could also use an event structure in a separate loop to set the property nodes. For instance, add the "Value Change" event on "Human gait cycle control" and "Graph Width", and move the code updating the property nodes inside it.
Message 7 of 8
(496 Views)
I took out the property nodes and I am trying to autoscale the X and Y.
The problem is that the X scale starts at -1million everytime even though my first timepoint is always 0, making the graph not display my data in a visible way:
What can I do to fix this?
Thanks.
Message 8 of 8
(485 Views)
