Display time when signal deriv equals zero
Say I have a simulated sine wave, I'd like to have an indicator show the time at which the wave's derivative equals zero. How would I go about this?'
EDIT: For simplicity, say I only care about the first time the signal equals zero.
(2,242 Views)
Maybe I am over simplifying it but if you input your derivative in place of the x control the indicator will change to the time x=0
=== Engineer Ambiguously ===
(2,234 Views)
Double = zero is a poor practice.  Why? Because of the way numbers are represented in binary in the computer the result of a calculation which is nominally zero may actually appear as a very tiny value.  It is better to compare to a range of values near zero.  You can use "Machine epsilon" (a predefined constant equal to the smallest non-zero value available on your computer), or some larger tolerance chosen on the basis of knowledge of your process.  For example if you have an 8-bit A/D converter with a 10 V full scale range, the smallest signal you can measure is 10/256 = 0.03906...  In such a system anything less than about 0.02 is probably zero.
Use In Range and Coerce? rather than Equals Zero?
Edit: The other issue is that a numerical derivative may never be zero.  If a data sample does not lie exactly at the peak the derivative values will change sign on either side of the peak but may never be close to zero.
Lynn
(2,210 Views)
I understand your point and in cases like you mentioned I would probably end up doing something like that.
But I have ran into more cases where doubles will equal exactly zero and need to act accordingly.
First thing off the top of my head, I work for a power supply manufacturer and often need to test transient response of our PSU's by step loading 0 to full load and full load to 0. When I step from full load to 0 I not only send the (double) value 0 to the electronic load but also use a (x)=0 to turn the load's input relay off fully disconnecting it from the UUT.  My vi's also have the opposite where (x)<>0 engages the loads input relay.
Notice I said (x)<>0 because the load has an internal crowbar circuit for short circuit testing, I set the load value to -1 and the load applies a short circuit.
(2,202 Views)
If you are sending a zero from a control or something like that you are probably OK. You do need to watch controls which have the increment set to a fractional value.  Increments which are not exact binary fractions can cause round-off errors at zero.  Calculations which should result in zero are more likely to cause problems.
Lynn
(2,194 Views)
