Display subvi of subvi in main vi subpanel
In my application, I have to display hierarchical sub vis in main vi subpanel.(i.e I am displaying a subvi in subpanel, when I click a button on the subvi, it will call another subvi and that called subvi should open in subpanel of the main vi) How to do it?
(2,226 Views)
You subVI needs to send a message to the main VI, telling it to change the VI in the subPanel.  The message content will need to include either the path to the VI or a reference to it.  I would use a queue to send the message, and for the data type of the queue, I would have a cluster containing a typedef'd enum (which specifies the message type), and a variant (containing message-specific data).
(2,181 Views)
Another alternative is to have it insert itself into the subpanel. You need to pass a reference to the subpanel to the appropriate subvi. Remove the existing vi and insert the new one.
(2,172 Views)
I believe there is an example of this in LV example finder.
Bill
CLD
(Mid-Level minion.)
(2,163 Views)
