Display/save 8 bit grayscale image
I have a VI that is capturing an 8 bit grayscale image (1D array of 1500 pixels). It has a 10 byte header that I strip off and try to display it.  The problem is that the displayed picture is interpeted as an RGB.  Also, the saved image can be opened using a picture viewer but is not correct.  It is missing the pixel data. How do I get this to display as an 8 bit grayscale image.  I would also like to duplicate the 1 row of image data to about 50 rows so that it is easier to view.  using a for loop and indexing the row only leaves the pxmao empty.
(4,029 Views)
Would you mind posting some sample data?
Patricia B.
Applications Engineer
(4,002 Views)
Accepted by Bjoles
Bjoles,
You are missing a colour table input to your flatten pixmap block. See the vi snippet I have attached. Also, I have found that building arrays from a for loop is a quick way of doing it, Labview seems to preallocate the memory correctly.
Luke_A_P
(3,988 Views)
The color table solved the issue.
(3,977 Views)
