Display real time on waveform chart x-axis when dt is not constant
I am logging data from a device through a RS232 serial port. The device streams data approximately every 6 seconds, but it may vary from 4 to 8 seconds. I want to use a waveform chart to display data, with x-axis being the absolute time.
I am using a code very similar to the Real-Time Chart.vi example. The problem I have is: since my data does not come in a constant interval, I cannot wire a constant to the  XScale.Multiplier.
Any suggestions?
Thanks in advance.
(4,094 Views)
There was a mistake in the previous description. I want the x-axis to be relative time.
(4,077 Views)
You could use an XY graph. If you want it to operate like a chart (i.e., an XY chart), then take a look at the example that ships with LabVIEW called "XY Chart". It uses a subVI as a buffer.
(4,073 Views)
pack your new value along with the real "t0" into a waveform data type and then plot those to a chart and make sure the "ignore attributes" is NOT checked. The Waveform data typ chart will plot the values based on the "t0" of the WF.
Ben
(4,069 Views)
The waveform datatype using the current timestamp certainly gets the job done.  Since you want relative time you will probably want to subtract the starting time otherwise you'll get rather large numbers on the x-axis.
-Darin
(4,063 Views)
