Display measurment data and change color depending on value
Hi folks.  I have a 1D array of double precision measurments.  There are 20 elements in the array.  I need to display them on the front panel as well as change the backround color of each element programatically if it is out of range.  There must be an easy way to do this?
Thanks in advance!
(2,700 Views)
You can't change the background color of just one element in an array.
=== Engineer Ambiguously ===
(2,685 Views)
Like the man says, you can't change the background color of just one element in an array. HOWEVER, there are a variety of other display options that could work, like listboxes.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,648 Views)
