Disconnected USB Camera Displays in MAX
I have a USB camera that shows up in NI-IMAQdx devices in MAX even after the camera is disconnected.  MAX displays the camera serial number.  When Grab is selected, get Error 0xBFF6901B timeout.
Any ideas??
(2,661 Views)
Did you try closing MAX and opening it again? still it shows camera?
-timeout tells you that whatever time you specified within which MAX is unable to connect/get data from camera.
-Provide screenshot also that would be more helpful.
uday
(2,644 Views)
Thanks, Uday.I opened/closed Max and also restarted the PC.  Still shows the camera as connected (see attached).
(2,618 Views)
Thanks for the update.
-Does MAX give same error when camera connected?
-What are the acquisition parameters?(Post screenshot when error occurs).
-I am not sure of this. Might be MAX database got corrupted and resetting it might solve the problem. Ref following link to reset MAX http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
uday
(2,614 Views)
