Disconnect type def LV2013
I've searched online and the Help/Example finder in LV with no luck. Everything I've found says to simply right click the instance and choose Disconnect type def. Unfortunately, the only option available I see is Open Type def. I don't want to delete the type def because it is linked to several other instances. Pretty embarrassed to ask such a simple question. I'm hoping it's hidden in a shortcut or menu. Thanks.
(2,728 Views)
Accepted by topic author amacapa
Right-click on the front panel, not on the block diagram.
Paolo
(2,724 Views)
Wow, thank you. I keep forgetting the panels are linked but separate.
(2,719 Views)
I think that should be fixed and the option made available from the BD. Opening the FP might send you who know where and creating a mess in the FP bound location.
(2,641 Views)
