02-27-2010 08:21 AM
I am working on cRIO NI 9012 and NI 9505 card for motor control.I want that motor and cRIO should stop working in case of TCP/IP connection failure(Cable unplugged or connection failure).But when i unplug the TCP cable from cRIO the connection with cRIO fails but it keeps on working with initially burned program parameters and motor keeps on running.
PLease help me out in this matter.
Thanking in advence.
Best Regards,
Shoaib
02-28-2010 02:13 AM
Hi Shoaib,
what have you done so far? Do you react in the TCP connection failure? You can use a watchdog.
Mike
03-01-2010 04:27 PM
