CHZ wrote in message <38d78b86@newsgroups.ni.com>...
>Hello,
>is it possible to disable parts of a VI (like /* .....*/ or //..... in C)
>I do not want to CUT and PASTE in a new VI, and afterwards CUT and PASTE
>back.
>Thanks, CHZ
Use a case structure and tie that to a boolean constant, you can turn it on
or of manually.
In the other case you can easily create constants to replace the outcome of
the code (if there is any) you would like to disable.
Later when you do want to use it again, select the case you would like to
use and choose "Remove case structure". You'll get a warning that the code
in the other case is wasted but those were constants anyway (or empty).
RB.
