Disable clicking on the main scream when the sub-VI is called
Hi all,
When I open the front panel of sub-VI from my main window (by using SubVI Node Setup > Show front panel when called), if I click a button (or something else) on the main window, it will still work after I close the subVI window. Is it possible to completely disable the clicking on the not used window  when the sub-VI is called (two windows opened at the same time)?
Ian
(3,651 Views)
Accepted by topic author IanYuan
Check the settings of the subVI to make it modal.
(3,642 Views)
Thank you so much!
(3,635 Views)
Just be careful when using modal windows.  You can get into a situation where your main and subVI are deadlocked and nothing can be done to exit.  Ctrl+. does not work.  Usually requires Ctrl+Alt+Del and you lose any unsaved work.
I'm not aware if this has been addressed somehow in newer versions of Labview.
aputman
(3,566 Views)
Another option is to use the Transparency property to hide the calling vi.
Like this:
This might give a cleaner look depending on the situation.
You can also do both (use partial Transparency) to make it clear that the background vi is inactive.
In general, I avoid Modal vis (aputman makes a good point - been there), but sometimes they are the best solution.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,553 Views)
