Disable all keystrokes than numeric in multicolumnListbox
Hi Altenback.
Okay now I certainly see you point. I would like to recreate the sample code you posted.It will be easier for me to visualize and understand. But how do I make the
“ok button”, “cancel button” value change?
I guess it's not possible to make headers to your numeric popup array?
Michael
Message 11 of 15
(778 Views)
@Michael.Koppelgaard wrote:
But how do I make the“ok button”, “cancel button” value change?
Not sure what the question is. Do you have the event structure? (not available in LabVIEW base until a few years ago). If you don't have it, you simply need a polling loop. No big deal.
You can make the popup as elaborate as you want. It is just a VI! For example the control could be an array of clusters where each cluster contains a string, an integer array with two elements.  You can add decorations and free labels, etc.
Message 12 of 15
(775 Views)
I simply have to try it - thanks 😊
Message 13 of 15
(767 Views)
Hasn't that been in Base since version 7.1 or something? 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 15
(733 Views)
Hi Altenbach
Since you are not that happy about listbox for user input, would you recomment  an array of clusters as frontpanel?
Message 15 of 15
(596 Views)
