Hi
Can you possible direct me to the information, I cannot find it on the NI
website
(I may be being blind here...but had a good look around and searched )
andy
BTW, I am not using VI's, im using CVI
Greg McKaskle wrote in message
news:37B8C07C.77E168BE@austin.rr.com...
> > Has anyone managed to get a direct (raw) print to LPT1 ?
> You can find details in an NIWeek presentation from two years ago.
> You can use serial port VIs to output bytes to LPT1, or you can
> use a DOS window to redirect a file with something like "type
> output.txt > lpt1" or "copy output.txt lpt1". There are some
> tricks having to do with getting the DOS window to work and
> getting the serial configuration setup in the .ini file.
> Gr
eg McKaskle
