10-14-2014 12:07 PM
HI Marius,
I have seperated the DAQ creation from DAQ write. On my system it takes about 7ms to write data ( Write a digital waveform with 4200 lines ( number of samples ) and write data to 16DAQ lines in parallel)
I still don't understand why it takes 7ms or even 2ms. I have 4200 samples and I write at 10MHz so it should take about 420us top write the data. Is there a difference between digital waveform and normal numeric array in terms of size?
10-14-2014 12:18 PM
10-14-2014 12:22 PM
Dennis
yes I measured it . It is exactly what I expected
I need to write multiple times. Is there anyway to load samples all at once ( maybe buffer them ) and then write multiple times? How much usually is the start time?
10-14-2014 12:27 PM
10-14-2014 12:37 PM
It is finite number of samples. Let's say I want to write 4200 samples 10 times .
Can I craete the task, set timing, buffer 42000 samples and then write 4200 samples 10 times and after each write I close the task
finally clear the task?
10-14-2014 12:43 PM
I tried that actually. Not multiple times but just 1 time
It didn't help. I completely removed the timing VI+buffer the sample VI and just left DAQ start+write to DAQ+ stop DAQ
It still takes 7ms to complete and write 4200 samples
10-14-2014 02:35 PM
