Digital to Binary conversion!
Are you talking from making a subVI?  Or just branching the wire so data goes to multiple places on the same VI?
GCentral
Message 11 of 14
(722 Views)
I am using bit Numerical control to input my decimal input. Then I am using a split number to convert that to t 16 bits and then again 2 split numbers to spilt it into two 8 bits. I want these seperate 8 bits as an input in the other VI but I can copy this whole code to the Controlling VI where I want to use these values.
Thank you.
Message 12 of 14
(721 Views)
Put the code one place or the other. It would be silly to duplicate it.
Message 13 of 14
(714 Views)
Accepted by Mohit1991
Yes. I am putting whole code at same point. I found the solution by the way, I split the number 2 times and then created a control variable for each byte. Converted it to read and then built an array out of it,
Thank you for your help.
Cheers!
Message 14 of 14
(711 Views)
