Under Labview 8.2.1, the formatting information associated with a chart display no longer sticks. When you run the program, it reverts to a %.2f format. In the older versions, you could set the format and it would remain during the life of the VI. In this version, I needed to change the width of the display, location of the digital display, and the legend. It seems during the operation of making the digital display visible and invisible, the format for the digital display changes.
Is this something new in Labview or you could never do it?
I have included an example of this problem in the library file. I f you run digital_display, you will see the behvior.appear. In the initial setup, the digital display is %.3e. You will see the format change, which change the display value from exponential to 0.00
