Differenze between two consecutive peaks to calculate the period of a signal
Hi deuchi,
finally you made it to attach a VI with some data…
When correcting the previously mentioned items I get this:
I get each peak in your (noisy) data…
(I also marked the AutoCleanup tool with a red arrow!)
Message 11 of 21
(1,085 Views)
If you can measure the frequency over (say minimum) 5 periodes (better 10 or more) you should give the tone detection vi a try to measure frequency and amplitude 🙂
If you need a good result (less disturbed by noise) between each periode (or even less than a periode) you should make yourself familar with the correlation function.
hint : if you only measure one channel you can read the DAQ output as a single wfrm...
tone detection comes with different types and accept single wfrm and wfrm arrays
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 21
(1,080 Views)
Thank you, GerdW for showing me the problem. Now I can see the red dots finally, it was because I forgot the input. But the data I have is like this, and I only need one peak, the highest in value. Any idea how can I fix this by ''playing'' with the peak detector?
Henrik_Volkers, I will try to use that VI.
Message 13 of 21
(1,073 Views)
In the help file to peak detection you can read how it works (fit a square function)
so if you increase the points width  you are less sensitive to noise but if you fit too much points, you have a systematic error because you fit a square function to a sine shaped peak.
But works fine if you use about the top 5 % of the sine peak. How many points width that will be depends on you sine freq, and samplerate.
However if you know that you have a sine, the tone detection works much better.
For a single periode a (interative) 4 parameter sine fit (f,amp.,phase,offset) would be my choice.
Henrik
LV since v3.1
Message 14 of 21
(1,050 Views)
Henrik,
I read the help file. It says that the value should be no more than about 1/2 of the half-width of the peak. How can I calculate the half width of the peak?
For example, I'm using a sine with frequency 5Hz and samplerate 16k. How can I get the value of my width?
Message 15 of 21
(1,030 Views)
May I ask how many years of math classes you alredy had?
one periode are 2pi or 360°
how many samples do you have per periode?
Spoiler
Samples per second divided by number of periodes per second  ..... 16k/5 =3.2k 🙂
The help file tell you to take not more than half width of the pulse,
I recommended to only take the top 10% better 5% of the sine peak.
Do you remember the arcsin function?
Lets see,  arcsin(0.95) results to ~71°, make it 70 .. remember sine? 90° it the top, so we want 2 * (90°-70°) = 40° of the 360° . How many samples will that be?
Spoiler
3.2k *40/360 ~ 356 sample 😄
Henrik
LV since v3.1
Message 16 of 21
(1,027 Views)
here is the systematic error you make with peak detection on a sine peak:
if you know you have sine use tone detection* or a sine fit
*) tone detection with at least 5 better more than 10 periodes
Henrik
LV since v3.1
Message 17 of 21
(1,022 Views)
Just realized I took 0 as the starting point. The half peak width also could be seen as the zero crossings.. so half a periode 😄
... result into a 2% to low error 😉
BUT migth be not too bad if only the time/position is needed ....
Henrik
LV since v3.1
Message 18 of 21
(1,020 Views)
Henrik,
I have had analisis classes during the two years of the university, we didn't do this arguments...
But thank you so much for your detailed example. I think I can get the peaks right for now! Can I ask you a last favor, to please attach the vi you used to show my error?
Thank you again for your patience!
Message 19 of 21
(1,018 Views)
Basic trigonometry should have been covered before you are allowed to enter university 😉
I was tempted to not post the vi to force you to learn basic math (and some LabVIEW) ... however
Here we go ....
Henrik
LV since v3.1
Message 20 of 21
(986 Views)
