Different tree shortcut menu for parent and child items
Hi people,I am trying to write a vi with with a tree control..i have been able to create a shortcut menu  for the parent item by right clicking on the tree control->Advanced->Run-Time->Shortcut Menu->Edit....However ,i would like to create two shortcut menus,one specific for the parent item and the other specific for the child items....any help?thanks
(3,768 Views)
Accepted by topic author alpony01
I think you need to dynamically create your run-time menu depending on the item that was selected in the tree control. You can do that using the run-time menu events and the menu functions in LabVIEW.
There's a palette for that:
(blog)
(3,745 Views)
problem solved...using the event "shortcut menu acitvation",i have used point row column invoke node to identify the name of the clicked item..then i have have used the "delete munu items" vi from the menu palette to delete the previous short cut menu and insert menu items to create the new shortcut menu
(3,736 Views)
