Dialog for Adding a new C Series Module to a cRIO9053 Target (RT Project) not available
Hello together,
I have an existing RT Project, which runs on my cRIO9053.
In order to add new functionalities to my project, i arranged a new NI9221 C Series Module and plugged it in.
According to the manual, i tried to add the new Module to my project by right-clicking "Real-Time Scan Ressources".
But there is no "Add" Option in the dialog.
When I try to rightclick my cRIO target, then select "New" --> "Targets and Devices", the attached dialog appears and says:
"You can have only one chassis per controller. There is already a chassis associated with this controller."
When i have a look inside NI Max, the new C Series Module is listed correctly and works fine. There is just no possibility to add the Module to my project.
Is my cRIO target somehow locked or what could be the issue here, so that adding a new module is not possible?
Thanks in advance for your help!
Message 1 of 9
(2,113 Views)
Hi Peet,
Unfortunately you forgot to attach the lvproj file as this one contains the definition of your whole project including all hardware/target information!
Usually you should have an option to search for new modules inside the chassis, that's how I used to add new modules to an existing project…
On your "RT control": the dt setting for the PID functions don't fit to the iteration time setting of the TimedWhileLoop…
Message 2 of 9
(2,097 Views)
I somehow can't attach the project file.
Error Message: "The attachment's fischer dk-tool.lvproj content type (application/octet-stream) does not match its file extension and has been removed."
Will a dt of 0,001 fit the TimdWhileLoop? Sorry for asking!
Message 3 of 9
(2,092 Views)
Hi Peet,
Instead of attaching several individual files you can easily put the whole project folder (including the lvproj file and others) into a ZIP file. Then attach that single ZIP file…
When you set your TWL to iterate at 1ms intervals then you should set the dt input of the PID function to 0.001s…
Message 4 of 9
(2,070 Views)
You can find the Zip Folder attached.
Thanks in advance!
Peter
Message 5 of 9
(2,065 Views)
Hi Peter,
as easy as usual:
I just took a look at your PCMain VI:
  • You really should cleanup here!
  • Never hide the labels of terminals in the blockdiagram!
  • Place buttons into their event cases.
  • Try to avoid "value" property nodes when the terminals are unused (!)
Message 6 of 9
(2,061 Views)
Hi Gerd,
that is exactly my problem. The "Neu" Submenu doesn't appear in the dialog an my PC. The first option in my case is "Verteilen".
Message 7 of 9
(2,055 Views)
@Peet95 wrote:
Hi Gerd,
Then something with your CompactRIO driver software installation is hosed. I would do a repair/reinstall of the CompactRIO drivers.
Rolf Kalbermatter  My Blog
Message 8 of 9
(2,046 Views)
Accepted by topic author Peet95
Good morning,
the Problem was the LabView Version itself. I had the 64 Bit Version installed. As soon as i installed the 32 Bit Version, all worked fine!
Thanks!
Message 9 of 9
(1,987 Views)
