02-24-2021 07:58 AM - edited 02-24-2021 08:02 AM
Hello, I want to read and write commands to protocol Can J1939 and I would like if you can tell me what device I need to communicate with this protocol, or what you recommend to use because I want to send and read the commands from Labview and I want to controller 2 Linear actuators Thomsom so I don't Know what device used to communicate between LabVIEW and actuators Thomson with the protocol j1939.
Thank you.
Regards.
Solved! Go to Solution.
02-24-2021 08:13 AM
Hi Roger,
You need to use device providing a CAN port.
I often use simple NI9853 modules…
02-24-2021 08:41 AM
Thanks for your answer GerdW I Read the Datasheet from NI9853 but we don't have the Compaq RO and want to ask you if I can use this Module USB-8551 PartNumb. 784662-01.
Regards.
02-24-2021 10:06 AM
There are no USB-8551 device from NI, but there is a USB-8501 and a USB-8502 CAN device.
The 8501 is a Low speed CAN device. To use this you need to make sure that your CAN bus is not running with a higher speed than 125k baud rate.
I will suggest to use the USB-8502 CAN hardware for your J1939 communication.
Are you planning to program your own J10939 implementation or are use using 3rd party toolkits ?
03-04-2021 07:53 AM
I would like to use the library from NI, which I found in the NI example with Library from j1939.
Regards.
03-04-2021 08:04 AM
Hi Roger,
why don't you call your local NI sales office to have give suggestions!?
I don't use that library (nor did you supply a link), but I guess somewhere in the description of that library there is information on the supported hardware…
03-04-2021 08:16 AM
Hello, I reviewed the blog from national, and yes the hardware that specific is to CompaqRIO.
thank you for clarified the questions.
Regards.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
