05-27-2026 11:13 AM
See title. My dev environment takes quite a while to open; at least a couple minutes. I thought my installation was just getting a little big with all the random packages I've installed, but then I installed LV 2026 on a new computer, and found that it's also taking multiple minutes to start up.
This decade-old thread (https://forums.ni.com/t5/LabVIEW/LabVIEW-Initializing-Plug-Ins-takes-too-long-time/td-p/3334343) mentioned that disabling an internet connection seemed to speed it up, and holy cow, it makes it WAY faster. Maybe 10 seconds between "click LabVIEW icon" and the Welcome window coming up.
Is there any way to make this startup process faster? I've already checked and I don't have any network license servers mapped at all, and I don't have any plugins installed that check for licenses as far as I know.
05-28-2026 04:02 AM
I don't know if this will help, but try checking the "Disable ni.com updated in Getting Started window" option in the Environment page of the options. This used to be an RSS feed of updates that LV gets. I don't know if it's still a thing and I don't know if it would actually delay something.
05-28-2026 04:16 AM
Any problems with your license server, or are you using local licenses? My LabVIEW takes absolutely ages to startup if I'm not connected to the campus network as it tries to connect to the license server and eventually returns with a message that I'm in Evaluation mode for a few more days and soon that I have no license to run it.
05-28-2026 11:08 AM
I'm using a serial number for activation, so I would assume it's connecting to NI to validate. But I'm not sure why it would NEED to do that because my license manager shows that the key is still valid for a while. Maybe it's just checking every time anyway?
05-28-2026 01:11 PM
Instead of assuming... verify!
Use the "Resource Monitor" application and you can see all network connections made by a given EXE.
Alternately, if that turns up nothing, install Procmon. You can add a "duration" field to everything it logs, so you can look only for things that take a long time to execute, as well as filtering it to certain EXEs only. You might not want to filter it just to LabVIEW.exe because it could be one of the NI services or something, but you can filter out anything that's obviously not a NI application that regularly runs long-duration operations that show up there.
05-29-2026 04:06 AM - edited 05-29-2026 04:10 AM
If you are using a serial number to activate, you are basically using a local license. That should not cause a license server verification on ni.com every time you start up.
What kind of drivers, addons and toolkits did you install? If you for instance installed any of the Realtime, FPGA, IMAQ or other licensed Toolkits but don't have a license for one of them, this does trigger a license server verification. Basically when LabVIEW starts up it checks for all installed Toolkits for a valid license and if one of them isn't, the license manager may try to query your local campus/corporate NI license server or the NI license server for a possible activation. And that can indeed take ages if there is none. So make sure in your License Manager that not only LabVIEW is showing as properly licensed but also any of the Toolkits.
If your License Manager doesn't show any unlicensed Toolkits, the next thing that could cause such delays is a bad or corrupted installation of one of the drivers, toolkits or addons. LabVIEW does try to initialize many of them during startup and if one of them hangs, it can take a long time until the timeout kicks in and LabVIEW continues anyways to start up.
05-29-2026 04:23 AM
if you had a labview subscription , valid for 1 year, this is plausible
you get a grace period of a few days or weeks after the subscription has ended
after that, you can't use the Labview IDE unitil you get a new licence
this does the google gemini AI say ( notice the hallucination for source [3], which has nothing to do with labview IMHO)
Your assumption is correct. LabVIEW checks its license status regularly, even if your License Manager shows a valid expiration date. [1]
## Why LabVIEW Connects Online
* Status verification: The software pings Native Instruments (NI) servers to ensure the serial number has not been deactivated, refunded, or upgraded.
* Subscription heartbeat: For subscription licenses, the software requires periodic online check-ins to prevent users from altering their system clocks to bypass expiration dates. [2]
* Usage tracking: It syncs seat compliance for volume license agreements.
## How the Grace Period Works
* The Buffer: When a 1-year subscription expires, NI typically grants a 14-day grace period.
* Functionality: The LabVIEW IDE remains fully functional during this brief window.
* Notifications: You will receive daily warning prompts reminding you to renew.
* The Lockout: Once the grace period ends, the IDE blocks access completely until you activate a new, valid license key. [3]
To help troubleshoot or clarify your setup, could you tell me:
* Are you encountering a specific activation error code or message?
* Is this an individual subscription or part of a company/university volume license?
* Are you working on an offline computer that cannot reach the internet?
I can provide the exact steps to bypass online checks or resolve activation hang-ups based on your situation.
[1] [https://forums.ni.com](https://forums.ni.com/t5/Developer-Center-Discussions/When-is-the-license-sta...)
[2] [https://forums.ni.com](https://forums.ni.com/t5/LabVIEW/Internet-connection-needed/td-p/4452423)
[3] [https://my.f5.com](https://my.f5.com/manage/s/article/K000160443)
05-29-2026 06:32 AM
@alexderjuengere wrote:this does the google gemini AI say ( notice the hallucination for source [3], which has nothing to do with labview IMHO)
Ant they renamed NI into Native Instruments too. Yeah.
05-29-2026 07:15 AM
In 25 that option doesn't exist, but you can disable the Getting Started window which seems to help.
