04-24-2018 03:34 AM
Hi all,
Here i am using labjack U3 LV and i interfaced with labview, once if i close and open the labview(not only vi), the port is detecting, unless i remove and reconnect the USB everytime. I have attached a example code here for your reference, please take a look into it.
Thanks in advance for your favourable reply,
Dinesh
05-09-2018 09:43 AM - edited 05-09-2018 09:56 AM
You should be using the Close function after you have finished with the device. This will release the device for connection again.
Example close function attached.
