08-05-2020 12:18 AM
Hello!
I'm Sean, and I'm totally a newbie but I have to deal with NI-9074, and I connected it with the computer using Ethernet. In NIMax, it can be detected in Remote systems. Then I attached NI 9265 and NI 9213 to NI 9074, but I found the modules nowhere in any of Ni programs. Is it a driver problem or something that I miss?
Solved! Go to Solution.
08-05-2020 12:36 AM
Hi Sean,
In MAX you will detect any remote target/device, like your cRIO-9074. But MAX will not show the modules in the cRIO chassis.
Instead you can add the modules to your LabVIEW project in the cRIO target branch. (Read the cRIO basics tutorial about these steps!)
08-05-2020 11:42 AM
Appreciate. It works!
08-06-2020 04:50 PM
Hi, @seannavis,
If you have a moment, could you mark @GerdW's reply as a Solution?
That way, if someone else has a similar problem and finds this post, they will know exactly where to look.
I'm glad @GerdW was able to give you the help you needed!
-joeorbob
07-12-2021 10:00 PM
Hi GerdW,
Sorry to dig up this thread again, but could I ask which cRIO basic tutorial you are referring to? Thank you!
ds97
07-13-2021 01:31 AM
